New engine crank no start
installed new cam and crank sensors. Running ls3 throttle body.
I’m getting crank no start.
No Ecm codes.
BCM code is U1511-00 Lin Bus 1 lost comms with device
edit: just installed the old crank sensor and same thing. I did verify that all my grounds are one. 2 on the passenger head, 1 on the driver head and 1 near the driver engine mount.
Was correct reluctor wheel used? It should be a 58x if you are using the 09 stock PCM.
Was the reluctor replaced?
Have you checked all fuses?
