E67 pcm pinout
Old Feb 11, 2025 | 05:03 AM
Jone's Avatar
Default E67 pcm pinout
I need e67 pcm pinout info. I am swapping a 1967 camaro for a 2012 lsa engine. Thanks in advance if anyone can help.
Old Feb 11, 2025 | 11:31 AM
pannetron's Avatar
Default E67 CTS-V Wiring Diagrams
What wiring harness are you using? I attached some wiring diagrams that may be helpful.
File Type: zip
Old Feb 11, 2025 | 08:40 PM
@the_merv is a wiring wizard. Hopefully he will jump in here. Moving this to external…
Old Feb 12, 2025 | 01:12 AM
Jone's Avatar
Thanks for the quick response and the wiring diagrams.
I used an aftermarket standalone wiring harness.
Do you possibly have the pinout of the ECM connectors?
Old Feb 12, 2025 | 04:16 PM
the_merv's Avatar
Veteran: Air Force
My knowledge is in the Gen III LS stuff, maybe LT1Swap.com has what you're looking for. That guy put a ton of info on that site.
