1-7/8 headers on 5.3?
Old Jun 9, 2025 | 10:09 PM
HappySalesman's Avatar
Default 1-7/8 headers on 5.3?
Hello all.
Been wanting to put some headers on the 5.3 in my trailblazer. Only problem is the only headers that are available now are meant for the 6.0, and are a 1-7/8" primary. Is this size of primary waaay too big for a 5.3 or can I get away with it?
Old Jun 10, 2025 | 05:35 AM
84ta406's Avatar
Stainless works headers are 1 3/4", I had them on my TBSS before putting the 402 in. I don't think the 1 7/8 are going to make much difference at all for you.
Old Jun 10, 2025 | 06:07 AM
showdog75's Avatar
1 7/8" primaries won't hurt you.
Old Jun 10, 2025 | 11:05 AM
Kfxguy's Avatar
Backpressure needed in exhaust is a myth. Let it breath.
Old Jun 10, 2025 | 07:58 PM
I know backpressure is a myth, however there is no ignoring that velocity is a thing, and an oversized exhaust pipe/primary can kill velocity which means you lose the scavenging effect, especially at low RPMs (where this truck lives, as it's my DD). I don't mind if I lose a few hp/ft lbs down low, but I don't want it to become a dog just trying to drive around town.
Old Jun 11, 2025 | 06:22 AM
Kjduvall's Avatar
itll be fine, i ran some tsp 1 7/8 on my 4.8 ly2 silverado with a true dual set up and x pipe, i had no issue at all. plus itll give you room too grow if you add more power later on. im glad i went that route cause later on i did a procharger p1x.
Old Jun 11, 2025 | 07:20 AM
Old Buzzard's Avatar
" I don't mind if I lose a few hp/ft lbs down low, but I don't want it to become a dog just trying to drive around town."
Then put the stock manifolds on.
Old Jun 11, 2025 | 08:22 AM
Kfxguy's Avatar
it's a 5.3.... so unless you add a turbo or a blower..... it's already a dog.
Old Jun 11, 2025 | 08:43 AM
kinglt-1's Avatar
Holdner tested it on a basic 5.3 and the 1 3/4 were actually a little better than the 1 7/8 on average. I believe something like + 8-10ft lbs more torque down low midrange and a 2-3 HP less up top. Either way it's nothing drastic.
Old Jun 11, 2025 | 03:28 PM
Fast355's Avatar
Where you will notice the loss of the oversize primaries the most will be at part-throttle not WOT thus the full torque loss of the larger primary will not be seen on a dyno but you will feel it every time you accelerate from a stop or try to maintain speed uphill on the highway.
Old Jun 11, 2025 | 10:33 PM
NSFW's Avatar
Just push the skinny pedal a little further down, it'll compensate.
Unless you push it all the way to the floor, in which case you should downshift, that'll more than compensate.
Old Jun 11, 2025 | 11:33 PM
hot98z28's Avatar
I lost low end torque going from 1 5/8 headers to 1 7/8 noticeably yes it made mor power but lost so much down low it felt slower. Every c6 guy with an ls3 at least when i looked it up said youll be faster overall with 1 3/4 on a daily unless your car lives at 7k rpm.
Old Jun 12, 2025 | 04:02 PM
IGN-1A's Avatar
Default Pipe Legnth
How LONG is the primary pipe ?
Old Jun 14, 2025 | 07:00 PM
hot98z28's Avatar
You will lose low end torque, idk where this thing came where tuners are recommending 1 7/8 headers for a 5.3. I had a built ls3 in my camaro and when i found out i had 15/8 primaries went to 17/8 and it did pick up some power on the top end but i noticed how much weaker it was on the low end.
everyone on the corvette forums was saying to go 1 3/4 as i would gain a lot more low end. 17/8 only added like 7hp on someones build and it was at really high rpm but he lost like 30ft/lbs torque on the low end.
Old Jun 14, 2025 | 07:01 PM
hot98z28's Avatar
Sorry i didnt know i had already replied to this lol.
Old Jun 16, 2025 | 12:59 PM
Hmm, unfortunate. My main reason for looking at 1 7/8ths is that they're the only affordable option. 2.2k for SW headers is ****ing ridiculous. That's what a full Kooks dual setup for an F-body was a few years ago.
Old Jun 16, 2025 | 03:01 PM
84ta406's Avatar
Just buy the speed engineering ones like just about everyone else does. I will say the fitment is OK and the install sucked compared to my ARH headers on the TBSS.
Old Jun 16, 2025 | 05:05 PM
68Formula's Avatar
Because one time an influencer tested it on a dyno with a built 5.3L (probably from 3000rpm+) and it showed only a small difference. Now they apply the logic regardless of the engine combo, vehicle combo, rpm, and let's completely ignore the fact that what happens at WOT doesn't necessarily translate at part throttle.
Old Jun 21, 2025 | 03:58 AM
And that's exactly why I'm asking. No sense spending all the money and time and effort if it's going to make the thing a bear to drive around town with.
