CR too high for 93 Octane? L96
I have a 2012 L96 6.0L engine I rebuilt and built for more power, I had the block bored 0.030" oversized. I installed flat top pistons with valve reliefs -1.2cc. The factory 823 heads were never milled and I used a cometic 0.051" compressed thickness head gasket. I installed a Texas Speed L92 stage 2 truck cam. 220/232 0.600 lift 112 LSA. Long tube headers. Factory truck intake. Factory harness and factory E38 ECM Black bear tuned. Using EFI and data logging custom tuned.
I run 93 octane 10% ethanol. Under load and low rpm the engine stumbles just enough to feel a slight bump in my butt. it never stumbles at higher rpms. I replaced the plug wires and plugs and it still did it. I replaced all the coils and it still does it. I then installed an Ethanol content sensor inline in my fuel line to read the ethanol content so I can run E85 and the E38 is now tuned to correct fueling on the go according to the Ethanol content. Running E85 the stumble has gone away almost completely but every once in a while I feel a slight stumble. I replaced the oxygen sensors, mass air flow sensor and MAP sensor and it had no effect on it. Being that it stumbles always running 93 octane and is almost completely diminished running E85 I have come to believe its octane related as E85 is somewhere around 100-105 octane depending on percentage of Ethanol to gasoline. The L92 6.2 has flat tops and has 10.5:1 CR with 823 heads. My L96 with flat top heads shouldn't be more than 10.5:1 CR
Last week it did a thing at startup. It backfired through the intake at startup then cleared up and ran fine. It has never done that before or since.
What gives?
on my face. There's a couple of fuel stations around here that sells 90 octane ethanol free and I'll be trying some of that fuel with the VP additive soon.
