Carb recommendation.
Old Sep 5, 2025 | 10:19 AM
racer9's Avatar
Default Carb recommendation.
Bracket car, 6.0 LY6, stage 2 cam, forged pistons, 10.5-11:1 compression. Powerglide. Planning to keep it under 6500 rpm.
I have a Holley 3310 750 vacuum secondary, which is likely not the best choice.
Go to a 850 or stick with 750?
Demon, Brawler or ?
Thanks.
Old Sep 5, 2025 | 11:06 AM
You want a mechanical secondary carb. Put that vac carb on your grandmas Caprice. Seriously though, here’s a link for a VERY high end carb built by a big shop. It’s on EBAY, but trust me here…I buy a LOT of stuff from these guys. Everything they sell is quality…used, but quality. Buy this carb. It prolly flows 1200+!
https://www.ebay.com/itm/18536167640...4AAOSwLwBji5g4
Old Sep 5, 2025 | 11:43 AM
racer9's Avatar
Thank you very much for that.
Old Sep 5, 2025 | 01:27 PM
IGN-1A's Avatar
Default Holley and Wegner Intake
I have used a Holly three (3) BBL carbbe with a Wegner intake AND a Ford 351-C Distributor for racing.
Lance
Old Sep 5, 2025 | 07:58 PM
Doug G's Avatar
I went with what I had, Original Mighty Demon 750 DP....I did have to jet it up a bunch, so I'm wanting to try an 850DP.
Similar motor, but unsure what "stage 2 cam" is ?
LY6, 10.8:1, 23X/24X cam on a 110LSA 106 CL .6XX lift
VS carbs for MPG....DP for ***** out.
5000 stall, TH350 MFVB
Old Sep 5, 2025 | 11:29 PM
racer9's Avatar
