Gen III 24x ECU TO Run A 24x LS2 ?
I have had a 2000 Ford F150 with a swapped 5.3/T56 combo. It’s a Drive by Cable truck. After 10 years, it’s time to do bigger boy chores. I have a 2005 LS2 24x long block on the engine stand. With a forged assembly and Truck Norris cam, it seems like a good motor for my needs. I would like to maintain the DBC configuration. I have a 6.0 Gen III DBC ECU. How can I make this work? When I Google this, AI gives me the following:
Key compatibility challenges
- Reluctor wheel differences: This is the most significant hurdle. The Gen 3 Vortec 6.0 ECM (e.g., the 0411 PCM) is designed for a 24x crankshaft reluctor wheel. Many LS2s are Gen 4 engines and come with a 58x reluctor wheel. To make this pairing work, you need to use a "24x" LS2, which was found in certain 2005–2006 models like the GTO and Corvette. You can identify the engine type by checking the color of the crankshaft position sensor: black for 24x and gray for 58x.
- Cam sensor signal: The standard Gen 3 Vortec ECM expects a 1x cam sensor signal. If your LS2 has a different cam signal (like the 4x found on later Gen 4 engines), it will cause a no-start condition or misfires.
- Drive-by-wire (DBW) mismatch: Early Gen 3 truck ECMs were designed for a cable-driven throttle body (drive-by-cable, or DBC). Later Gen 3 truck ECMS and some 24x LS2s use a DBW system. To use a Gen 3 ECM with a DBW LS2, you must ensure all the correct components (throttle body, pedal, and throttle actuator control module) are compatible. Some Gen 3 ECMs, like the E40, are designed for 24x DBW applications.
- Sensor locations: The cam and knock sensor locations differ between some Gen 3 and Gen 4 engines. A hybrid setup requires matching the sensors to the correct position for the harness you are using.
Plus need to cater for the front mounted cam sensor on the LS2 (extension harness) plus the 2 wire gen IV knock sensors on the lower block each side vs 2x single wire in the valley on gen III (which AI is a bit vague on), normally handled by attaching G III sensors on the block sides & running an extension harness also.
