LS2 water pump
Old Feb 21, 2007 | 11:08 AM
TwnTrboCE's Avatar
Default LS2 water pump
Can anyone give me the measurement from the flange where it mounts to the block to the most outer part of the pulley snout/shaft. I know it is shorter than a LS1 pump. I need to know exactly how much.
If anyone has a LS2/LS7 water pump they want to sell PM me.
Thanks.
Old Feb 21, 2007 | 12:19 PM
AintQik's Avatar
Tearing mine down tonight. I can check then but I'm sure somebody's got one apart
Old Feb 21, 2007 | 07:26 PM
AintQik's Avatar
5.35" from the block to the snubber deal on the end of the pulley shaft. That is the farthest point forward on the pump. The pulley itself is back a little bit.
Old Feb 21, 2007 | 07:43 PM
jtl12419's Avatar
I was told by Lingenfelter to use the same LS1 pump/TS housing as what I got on the LS2, and the same tensioner apparatus.
Old Feb 21, 2007 | 10:51 PM
TwnTrboCE's Avatar
Thank you very much. That is exactly what I needed to know.
jtl12419, I'm not sure what your saying.
Anybody got a LS2/LS7 pump for sale?
Old Feb 22, 2007 | 03:53 PM
AintQik's Avatar
Oh one morething I want to add. The LS2 radiator hose comes straight out the front of the pump. So, if you were worried about clearance this might be an issue. I guess you could make or have somebody put a 90* inlet there if you were getting creative. PMme if you need some pics. But I'm sure there are plenty of LS2 photos floating around the net.
Old Feb 23, 2007 | 08:40 AM
TwnTrboCE's Avatar
Thanks for the info, again. That won't be a problem.
