LS7 Water Pump
Old Mar 17, 2007 | 03:48 PM
the_merv's Avatar
Veteran: Air Force
Default LS7 Water Pump
Anyone know where to get one, or one that is thinner like it? We are dropping a LSX Engine into a car with not too much clearance up front, and that will work the best for what we are doing. Also, I need a Corvette Balancer/Hub Pulley, whatever you want to call it..
Old Mar 19, 2007 | 10:27 AM
philntx's Avatar
Default LS2 Waterpump
You need an LS2 pump from the 05+ vette.
Go to gmpartsdirect.com and type in 89017457
They are $167
You might be able to find it a little cheaper as a take-off.
If you askfor LS7 parts, I've had people want to charge more because it "comes from the Z06 motor"
Old Mar 21, 2007 | 11:21 AM
the_merv's Avatar
Veteran: Air Force
I just wanted the skinnier one..whatever one works.
Old Mar 21, 2007 | 11:38 AM
jonathan_ed3's Avatar
Can anybody tell me about the modification that needs to be done to the pulley (I read something along those lines) to make this pump work with an LS1?
Old Mar 21, 2007 | 11:52 AM
Oscar Will's Avatar
I had to pull the pulley forward about 3/8"(toward the radiator) to make it work on my LS1 in my old hotrod. Allows alot more clearance.
Old Mar 22, 2007 | 02:18 PM
Mia's Avatar
Mia
how did you pull the pulley forward?
Old Apr 29, 2007 | 06:55 PM
bigsticksupra's Avatar
