Fuel Injectors
Old Mar 21, 2007 | 01:45 PM
the_merv's Avatar
Default Fuel Injectors
Will the Injector Plugs on a 99 LS1 Camaro Harness work with the LS2 Fuel Injectors, I don't know if there is a difference..
Old Mar 21, 2007 | 03:11 PM
the_merv's Avatar
More detial- I guess 05 and up LS2 Injectors have little tabs on the side of the spot where the connection would go. My theory is that I could grind these down and have it connect to my Harness like it was factory, everything else appears to be the same.
Anyone have any Input?
Old Mar 23, 2007 | 12:18 PM
rocketman69's Avatar
I believe you have to change all the connectors on the harness to make them work. Caspers has pigtail harnesses for this application.
Old Mar 23, 2007 | 01:49 PM
the_merv's Avatar
I am going to see if the F-body Connectors will work if you take them tabs off of the Injectors.
