l92 or ls7?!
Old Mar 26, 2007 | 07:45 PM
Stang Killer's Avatar
Default l92 or ls7?!
ok...probably super stupid question for most of you, but i dont know the answer, so im asking it. Ive got a 6.0 lq9 block. now i was going to go with the l92 heads with the l76 intake, but do the ls7 heads and intake flow better then the l92\l76 setup? or can the ls7 stuff even fit on a 6.0 block? any help from you guru's would be great...i get ubber discounts at my local gm dealer (dont ask how) so id just like to know before i go spend some money
Old Mar 26, 2007 | 09:04 PM
03 BUSA's Avatar
Yes the LS7 setup will flow more. I am 85% sure that it will not work with the LQ9 though.
Old Mar 26, 2007 | 11:04 PM
CamaroSS22's Avatar
you can use the ls7 intake with the l92 heads. From what ive heard i think that the ls7 heads with work with the lq9
Old Mar 27, 2007 | 09:55 AM
hmm....2 differant answers! lol well thats good gets us all thinking.....anybody know off the top of your head what the differance in flow #'s are? or am i just waisting my time? lol
Old Mar 27, 2007 | 10:10 AM
SUTTERERMAN85's Avatar
the LS7 intake will not fit l92 heads. bolt pattern is different and ports are a little different. max bore for an 6.0L (lQ4 or Lq9) is .060 in most cases and that makes your bore 4.060" and you need larger than that for ls7 heads i believe. also ls7 heads are cnc'd. they will flow a lot better than the as cast l92's but cost at least 2x as much.
Old Mar 27, 2007 | 11:09 AM
8ty8 LS1's Avatar
the stock bore on the l92 is 4.065...i'm sure that can be expanded a bit?
Old Mar 27, 2007 | 11:39 AM
meant 6.0L (LQ4 or LQ9) going to edit and fix it my bad. and well the L92 block is alum so i am not sure how much it can be bored if any. im sure it can go .010 though. dont know much about them, havent got to mess with one yet...
Old Mar 27, 2007 | 11:51 AM
8ty8 LS1's Avatar
well the l92 have extra head bolts compared to the other engines...this would be better for boost correct?
Old Mar 27, 2007 | 03:37 PM
they have the same amout of head bolts. thats why you can use them on older blocks.
Old Mar 27, 2007 | 04:25 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Will the LS7 heads bolt onto an L92 block? YES, kind of...optimal? NO! It's kind of like putting the L92 heads on an LS1/6 block. They'll bolt on, but clearances are not good.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Mar 27, 2007 | 04:33 PM
WKMCD's Avatar
Go with a set of WCCH L92's they will flow 355/245 without a pipe and easily outflow the L76 intake. Take the money you saved and put it towards a Wilson Billet intake. I probably have one in next winter's plan.
My $.02
Old Mar 27, 2007 | 07:51 PM
My $.02
well shoot! tell me where to get em! lol
