6.0 intake ?
I have a ls2 6.0 shortblock im thinking about gettting the l92 heads and a comp cam to match but I want to run a carb setup is there any intakes made for carbs for the'se heads yet? if not what other options do i have i deff want to run carb and make around 500hp.
thanks brandon
thanks brandon
I think it may be listed in the sticky. If not GMHTP tested one and I think the part# is listed in the article. You can call SDPC and they can help you for sure.
Are you looking to really turn a bunch of RPM's?? 6500+++??
We normally keep them in stock and they sell for $299.50 plus shipping. Give me a call if I can help!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Because that is where the carb style intake really begins to shine. Any lower than that and the standard L76 intake is better. Not that the carb is a dog it is just the whole combo on a 6.0 is more skewed to really turn up!!
If you want 500 crank hp I would sell the standalone and get a fuel injected setup. You are going to need all the torque you can get with that rig. You can find a truck manifold pretty cheap and that will help in the torque dept. 500 crank HP with these heads is not hard. Everything associated with the L92 is relatively inexpensive.
well its not going to be awd anymore but its still a lead sled im kinda in a bind for money cuz i want to paint the truck too...i just thought it would be a little cheaper to go with the carb set up. what cam would u recomend for the motor ive been looking at some comp cams and i thought the comp XR265HR looked pretty good.
I would not even begin to try and give you the exact specs on a cam. I would think you would need something along the lines of a 224/232. That should be relatively close to what you would need. Like I said 500 crank hp with these heads is as easy as falling off of a log.
yea ive heard alot of good things about those heads...hell ive heard alot of good things about the 6.0 and i got a hell of a deal on my shortblock i couldnt pass it up. i figured i could build that cheaper than trying to rebuild my blown up 4.3 and get it tuned to the right turbo setup.
