LS2 intake vs. Fast 90
Dont just take my word for it....do some homework. There are plenty of threads that discuss how weak the stock LS2 intake is....very similar to an LS1 in power out, both of which are 5-7 softer than an LS6 even though the LS2 has a larger TB (which is usually never the real restriction and the reason it doesn't help).
Use the search feature....lots of info out there discussing what you seek.
Tony
Again.
Run #19 was the same 2007 LG Pro Long Tube C6 M6 with FAST intake manifold
Run #14 was done on a 2005 LG Pro Long Tube C6 M6 with a ported LS2 intake manifold.
As you can see there is a huge jump in torque throughout the RPM range starting around 3500 RPM all the way over 5000 RPM. At no point does it loose any HP or TQ throughout the pull.
LG Pro Long Tube headers + FAST intake, makes for a very potent package! Pick up a G5X series cam package to make for a Z06 killer!
