416 L92 will be runing tonight
Old May 23, 2007 | 04:27 PM
1bigcam's Avatar
Default 416 L92 will be runing tonight
i need to know if its all right to run the car on my tune i have now? right now the tune is for ls2 with a ms4 cam and bolt ons. also how long to break it in and how???
Old May 23, 2007 | 05:19 PM
1QuickT-A's Avatar
It should be ok to run it as long as you don't go full throttle.. I personally would get it retuned asap!
Old May 23, 2007 | 06:02 PM
edcmat-l1's Avatar
I would at least change the engine size and ifr. That'll get you close enough to not worry about the break in.
Just saw the engine size is the same as before. If the injectors are the same you should be fine.
Old May 23, 2007 | 06:28 PM
1bigcam's Avatar
no the injectors were ls2 now i have the ones that come with the l76 intake. i just need to break it in so i can take it to the dyno on the 31 to get retuned
Old May 23, 2007 | 08:07 PM
VortechC5's Avatar
I just fired my 427 a few days ago so I recently went through this.
You will need to change your IFR for the larger injectors. If not it will be too rich and that is not good at all for a new engine.
In addition to that you need to change the cylinder displacement. Since my car has ETC I also changed the ETC Throttle Area Conversion for the 90mm TB.
With these changes my car fired right up and runs supprisingly well with the rest of the tune being the one that I did for my heads/cam 346.
Old May 23, 2007 | 09:10 PM
1bigcam's Avatar
what is all that and how can i change it??
Old May 23, 2007 | 09:27 PM
1bigcam's Avatar
with the injectors only being 4 pounds bigger is it that big of a deal,
Old May 24, 2007 | 07:42 AM
JBM's Avatar
JBM
If you can borrow a MAF translator, you can set it to 10-15% lean to prevent washing the rings down. Drive it like a sissy until you get tuned.
Old May 24, 2007 | 12:02 PM
1bigcam's Avatar
i can put the stock ls2 injectors back in will that help, and still drive it like a sissy. i like that term but thats real hard i have a lead foot
Old May 24, 2007 | 01:11 PM
JasonShort's Avatar
Moderator
Well, its either: 1. drive it like a "sissy" or 2. take a real good chance at hurting the engine.
Old May 24, 2007 | 08:15 PM
VortechC5's Avatar
IFR is injector flow rate. You change it using tuning software such as EFILive or HPT.
Old May 25, 2007 | 08:53 PM
1bigcam's Avatar
i put the ls2 injectors back in and car still won't run. what can i do?? is the tune that far off. it was tuned for a big cam need help fast.
Old May 25, 2007 | 09:49 PM
JBM's Avatar
JBM
Tow the car to the tuner.
Old May 25, 2007 | 10:49 PM
sloganish's Avatar
werd
Old May 26, 2007 | 08:58 AM
TrekGTO's Avatar
My car ran so bad with just l76/l92 and cam that said no reason won’t run. Sounds like the obvious Wrong Cam Gear for Cam Sensor or Reluctor for Crank Sensor. Check with Scanner for all inputs not just codes. You need HPT to make adjustments for new engine. I found people on there forum very helpful and did a safe to run tune for me.
Old May 26, 2007 | 09:04 AM
VortechC5's Avatar
I think that it depends upon what was done in the first tune.
I just fired my 427 last week. All I did to my existing h/c 346 tune was change the IFR , bump the idle speed from 850 to 950, bump up cylinder displacement, the and make a change for the 90mm throttle body that the L76 intake has. It fires right up and idles fine at 950 rpm.
Did you change your cylinder displacement? This has a huge effect on most everything else.
Old May 26, 2007 | 09:49 AM
beardWS6's Avatar
Man good luck!
Old May 26, 2007 | 10:39 AM
White_Hawk's Avatar
Although I mostly advise against mail order tuning, you could probably get a mail order tune to get you close enough to get it to a tuner. I still wouldn't "get on it" until it sees a dyno, though.
-Geoff
Old May 26, 2007 | 11:53 AM
Quik's Avatar
wheres Red lion PA? depending on where your at. i might be able to possibly help you get to a dyno
Old May 27, 2007 | 12:30 AM
1bigcam's Avatar
i have a friend of mine coming. he is going to adjust the computer with hp tuners so i can run the car. thanks for every ones help
