L92 carb style intake
Old Oct 15, 2007 | 12:01 AM
TT LS2 1969 Camaro's Avatar
Hello...what are you fellas running as far as engine management for this type of setup?
Old Oct 15, 2007 | 07:36 AM
cam75w/ls1's Avatar
I'm sure it's the stock management system w/ custom tune.
Old Oct 15, 2007 | 08:20 AM
SUTTERERMAN85's Avatar
stock computer will work just fine.
Old Oct 19, 2007 | 12:37 PM
fastGBcamaro's Avatar
Any updates or results yet, whether or not this type of setup makes any more power than the L76 composite intake. Im not going to pay $600 + if I am only going to see 5 -10rwhp.
Old Jan 12, 2008 | 05:18 PM
2000 Ultra Z's Avatar
The elbow from edelbrock is out just ordered one from jegs be here on the 18th and painted the intake to match
Attached Thumbnails L92 carb style intake-elbow.jpg   L92 carb style intake-intake-carb-004.jpg
Old Jan 17, 2008 | 10:42 AM
s346k's Avatar
i am very interested in an L92 carb style intake, as i will be buying one. gmpp looks good, but i'd like to find a taller one as hood clearance will not be a problem for me. maybe edelbrock has will get something done in a couple months before i am ready to buy one.
Old Jan 17, 2008 | 11:01 AM
Area 51 Racing's Avatar
So what is the differance between a Gmpp and a edelbrock victor jr, other than price?? Can someone pm me and let me know
Old Jan 17, 2008 | 03:33 PM
03 BUSA's Avatar
Is there any real gains over the L76 composite intake? I have yet to see a back to back on this subject.
Old Jan 18, 2008 | 05:45 AM
s346k's Avatar
the only gains i've seen over an L76 are above 5,000 rpm. it appears the ls1 style composite intake is good for low-midrange torque, but has trouble moving air at and above 6,200 rpm. obviously the single plane carb style setup will have no problem feeding the motor some air.
Old Jan 18, 2008 | 03:02 PM
They have a taller one already but you have to cut the plastic piece on the windshied http://www.edelbrock.com/images/home/npb_2008.pdf
page 5
Old Jan 18, 2008 | 04:29 PM
BES Stroked Nova's Avatar
you can buy a L92 carb style intake with inkector bungs already there, go buy a fuel rail kit for a LS2, and use injectors for a ls1... its not that hard, oh and for the elbow, i got nitro dave's elbow.
Old Jan 18, 2008 | 04:46 PM
  #32
s346k's Avatar
this intake will fit L92 heads? also, i am not using a 4th gen. fbod, so hood clearance is not an issue.
Old Jan 19, 2008 | 01:17 AM
  #33
XLR8N's Avatar
IIRC Car Craft did a back to back test on a 6.0. They did L76, fueled carb and a carb set up.
Old Jan 19, 2008 | 11:18 AM
  #34
03 BUSA's Avatar
So what were the results??
Old Jan 19, 2008 | 12:00 PM
  #35
XLR8N's Avatar
whoops, let me find it.
Old Jan 19, 2008 | 12:24 PM
  #36
XLR8N's Avatar
I was wrong it was in GMHTP, but here it is.
http://www.gmhightechperformance.com...ads/index.html
Old Jan 19, 2008 | 05:06 PM
  #37
JDP's Avatar
JDP
im tempted to go with the carb style with an elbow, but dont know if the gains up top will be worth the loss down low.
cam is a 240/252 .650/.661 114+3, my car peaks power at about 6200, i know this cam needs to spin higher
Old Jan 19, 2008 | 10:25 PM
  #38
i bet it would be worth the gains, cuz they tested it on some ***** cam, stock cube LS2.
Old Jan 19, 2008 | 10:57 PM
  #39
TurboGibbs's Avatar
look for threads started by Turbogibbs in the dyno section I think. You will find an intake camparo dyno.
Old Jan 20, 2008 | 12:35 AM
  #40
slick1851's Avatar
Can he do a LT1 intake? Please PM me his info
