LS1 component compatibility with an LS2/7??
Old Jun 4, 2007 | 09:45 AM
chevrev's Avatar
Default LS1 component compatibility with an LS2/7??
i currently have all of the bracketry from a corvette LS1 including a custom made wiring harness(this is going into my 57 chevy) and a 4l60e transmission.
Will these LS1 components be compatible with an LS2 and/or an LS7 block?
thanks,
Old Jun 6, 2007 | 12:01 PM
Nasty N8's Avatar
LS2 Yes most all will be just fine there are a few sensors relocated that you have to get an adapter for and depending on the injectors used you may need adapters for those as well. But eveything esle should be fine. The LS7 requires a different computer or reluctor wheel change.
Nate
Old Jul 14, 2007 | 02:02 PM
snake charmer's Avatar
doesnt the corvette ls1 accesories vary from the fbody ls1 accessories ?
