Fuel and wiring for L92 engine swap in 97 corvette
Old Jun 11, 2007 | 10:02 PM
vjjack04's Avatar
Default Fuel and wiring for L92 engine swap in 97 corvette
I just had an L92 put together for my 97 Corvette. I am trying to tie up some details, especially wiring and fuel. I have the stock 2 fuel line set up, and the stock fuel rails work by I need some spacers, anyone done this and know if such spacers are there any available?
Several sensors have the mismatching connectors; can I change the oil pan sensor to an LS1/LS6 sensor instead of using the L92 sensor? I am getting a harness adapter for the knock sensors, the MAP sensor and the throttle body; I have had the computer tuned on a dyno, so the uneeded sensors have been turned off. Any advice or helpful information which can be provided for such a swap will be helpful- by the way the motor made 560 HP on a engine dyno (super flo).
John Jackson, Sierra Vista AZ
Old Jun 12, 2007 | 05:26 AM
WKMCD's Avatar
The fuel rails won't line up even with spacers. You will need to cut and reweld the mounting tabs and cut the crossover tube and join it with a piece of hose - not the best way to go. Tried it and it eventually leaked. It was temporary until I did this:
Old Jun 12, 2007 | 07:39 AM
See5's Avatar
You can make up spacer from <1" pieces of tubing. Just cut to fit.
The level sensor from your old pan will trade out with new pan.
Old Jun 12, 2007 | 08:23 AM
SS Blazer 07's Avatar
Doesn't Turn-Key have a special harness they sell to do this?
Old Jun 12, 2007 | 08:45 PM
vjjack04's Avatar
Thanks for the information. I really like the aftermarket fuel rail set up.
Another question: I see that there has been alot of discussion about PVC on the LS2 - How about the L92? I am only runing 10.5 to 1 compression and a .600/224 degree cam (approx) so can't I run a stock PCV set up?
Thanks for any information.
Old Jun 13, 2007 | 10:53 AM
See5's Avatar
It will work ok, but you will probably want to mess with it later.
I you look around you will find dozens of schemes.
Old Jun 18, 2007 | 09:50 PM
vjjack04's Avatar
Back to the question of putting the L92 in my '97: I know the cam and crank position sensors are in different locations, but are the connections the same from '97 to '04 (for all C5s?) Need to know so if I need to I can get a harness/adapter. I have adapters/extensions for all other sensors/controlers.
Thanks
Old Jun 24, 2007 | 01:39 PM
CODE4LS1's Avatar
Yes. '97-'04 C5's have all the same connectors.
