LS7 carb manifold gasket numbers
Old Jul 13, 2007 | 01:35 PM
Phil99vette's Avatar
7 Second Club
Default LS7 carb manifold gasket numbers
Does anyone have some part numbers for LS7 carb manifold gaskets?
Phil
Old Jul 30, 2007 | 07:22 PM
7 Second Club
T T T
Old Jul 31, 2007 | 08:27 AM
Richard@WCCH's Avatar
The Fel Pro numbers are 1208-2 (.045" thick) or 1208-3 (.060" thick)
The SCE number is 119102 and is only available in .060" thickness.
They all fit manifold numbers 25534394 and 25534413.
Richard
Old Jul 31, 2007 | 08:30 AM
7 Second Club
Thanks richard, I assume you run the same size Intake Gaskets as HG?
Old Jul 31, 2007 | 08:40 AM
Not sure who HG is but I stock intake gaskets for LS7 and L92 intakes.
Richard
Old Jul 31, 2007 | 09:02 AM
7 Second Club
Richard
hg is head gasket. Do you run a 43 intake gasket with a 43 head gasket?
Old Jul 31, 2007 | 09:09 AM
Doh!
Yes. As thin an intake gasket as possible unless you machine the intake flange an approppriate amount. I find that the intake gaskets hold the intakes up a bit too high and cause the port match to skew.
Richard
