Opinions on Heads and Cam for LS2
AFR Mongoose Heads: 205cc Intake Ports, 66cc chamber, 3 angle grind, 2.02/1.60 valves. 300 cfm @ .600 lift
Comp Cams Energy Extreme: Hydraulic Roller, .580x.590, 114 degree, (@.050in)…230 deg in/232 deg exh duration
Stock Compression: 11:1
Stock Manifold
Upgraded injectors to 30 or 40 lbs.
A couple people I've talked to mentioned using Ford red top or green top injectors. Mainly for the price, but I can't find any info on whether they will actually work on an LS2. Any suggestions?
Thanks,
