FAST 90mm Intake & Fuel Rail Help
Old Aug 26, 2007 | 01:03 AM
shovelhead73's Avatar
Default FAST 90mm Intake & Fuel Rail Help
I have a 2006 LS2. I bought a FAST 90 mm intake and Fuel Fail along with a set of LS7 injectors. First, the FAST intake injector boots are not compatible with the LS7 injectors or the old LS2 injectors. They sell a conversion kit but from the description it's a conversion for the OEM fuel rail and not the manifold. The second problem I noticed was the LS7 injectors are a 1/2 shorter than the LS2 injectors. Do you have to modify the FAST fuel rail mounting blocks to make up for the shorter LS7 injectors? Any help would be appreciated. thanks
