1-5/8" headers on an LS2
Old Aug 26, 2007 | 02:06 PM
scv8's Avatar
Default 1-5/8" headers on an LS2
I'm running an LS2 swap and my primaries measure 1 5/8". They are also mid length tubes ( they go to a Flowmaster Y-pipe and then into a single 3" catless to a straighthru Magnaflow). How much power do you think I'm leaving on the table with this setup, as opposed to let's say 1 3/4 LT's?
I'd greatly appreciate any input.
Old Aug 26, 2007 | 06:48 PM
Dragkid1917's Avatar
10-20 rwhp
Old Aug 26, 2007 | 10:35 PM
scv8's Avatar
Thanks Drag. That makes sense.
Old Sep 25, 2007 | 05:08 PM
Cheatin' Chad's Avatar
That entirely depends on how much air you are moving.
If this engine is capable of 500hp then you could be losing 40hp off headers that are too small. If it's near stock power output you may be losing very little and maybe none at all in some places in the rev range.
If you are just flat stuck with your header size then consider getting with someone that can custom spec a cam that can account for this. A cam that is designed with this situation in mind will result in a much better set-up than one that is not.
Old Sep 25, 2007 | 07:08 PM
SUTTERERMAN85's Avatar
are you going for a peak power car or street? you are probably leaving a little on the table in the high RPM's but i bet you will make more torque and have more mid range power as well. it would help if you would tell us what size cam you are going to be running.
Old Oct 3, 2007 | 08:57 PM
scv8's Avatar
Thanks for the replies guys!
