L92 valve cover bolts
Old Aug 30, 2007 | 01:11 PM
garrettpen's Avatar
Default L92 valve cover bolts
I have a 98 firebird so it originally had perimeter bolt valve covers. I am now finishing installing a L92 headed 6.0l. I bought a set of later style centerbolt valve covers with bolts off of a member here. I went to install them and the bolts aren't long enough. do i have to buy special bolts for L92's, or did i get the wrong bolts? From what i can tell measuring with calipers i would need bolts about 50mm long, the ones i have are probably half that.
Old Aug 30, 2007 | 04:30 PM
RGKSR's Avatar
Default L92's with LS1 Rocker Covers
My stock '00 LS! covers fit my L92 heads after I removed the baffle.
Bob K.
Old Aug 30, 2007 | 04:36 PM
garrettpen's Avatar
The covers fit fine the bolts just aren't long enough
Old Aug 30, 2007 | 09:18 PM
RGKSR's Avatar
Default The stock bolts work fine
The stock bolts work fine. You must have the wrong bolts
