LS1 Accessory Brackets on LS2?
Old Sep 1, 2007 | 10:44 PM
rd_ls1_z's Avatar
Default LS1 Accessory Brackets on LS2?
I'm considering an engine swap to either a 383 LS1 or 402 LS2. One of the deciding factors is will my current accessory belt system from my LS1 fit the LS2? Thanks for any and all input.
Old Sep 2, 2007 | 08:58 AM
JoeyGC5's Avatar
My vette brackets bolted right up without and issues on my L92. The only mod was the pass side motor mount needed a slight clearancing. Not sure if thi is a factor on an F-bod though.
Old Sep 2, 2007 | 01:39 PM
HSV-GTS-300's Avatar
Yes, bolts straight on. As will the starter motor, flywheel/flexplate, oil pan, exhaust,engine mount brackets etc etc.
Old Sep 2, 2007 | 01:50 PM
rd_ls1_z's Avatar
Sounds good, I don't want to fight with those too, thanks.
