LS2 truck to car manifold swap?
Well i was looking at putting a cam and nitrous on the TBSS. I was curious if there would be any gains from going to the car LS2 manifold over the truck style one. also does the truck manifold run the 90mm TB? i was looking at the Nitrous Outlet plate kits, which is why i am curious. They have the LS1 truck/TB (5.3) and LS2 corvett/gto but no LS2 truck. I was thinking of going with the TSP 224R ( TSP XS Series Camshaft: 224/224, .581"/.581" )with the comp 918's. Any opinions on that as well would be nice. Thanks
go over to performancetrucks.net and read up there. Its a sister site to LS1Tech... I'd recommend leaving the LS2 truck manifold in place. A lot of the GEN III truck guys are going from the GEN III truck to the GEN IV LS2 truck manifold because its a better design and uses a 90mm TB vs the 78mm stocker we have... There's some flow data floating around I'll post up for you but in a nutshell, the LS2 truck manifold flows where you need it to for a truck's weight and the Tq needed because of it... with that said again. I'd leave it as is. and do a nice cam/converter combo and some bottle.
http://www.performancetrucks.net/for...d.php?t=397720
if it were mine I'd go with a 224/228 .585/.598 112+4 (custom grind)... a Yank TBSS3200 converter and a 100/150 shot all day long... it'll easily put you in the 12's in that truck...the LS2 car nitrous plate would work for your truck as well I believe... call them and verify though...
