ls1 to ls2 help!
Old Oct 17, 2007 | 09:15 AM
dmoss69's Avatar
Default ls1 to ls2 help!
Alright fellas, I need some input!
I've gotta truck with a 6.0 liter engine that has bit the dust (knocking).
I've also got a lead on a 6.2 LS2, L92 engine that I can get my hands on pretty reasonible ($)!
Decisions…….Is it going to be worth it to buy the L92 engine and put it into my truck with more power, or rebuild the stocker (if block is good).
Problems
I know that the LS2 has the 58 tooth reluctor wheel on the crank, and my 6.0 has the 24 tooth, which I’m not sure if just a newer PCM swap will take care of? Will the wiring harness plug n play into the new PCM…..?
I also saw where the knock sensors will have to be moved to the block.
Both of these engines will be from trucks, and I know I'll have to buy a throttle body for the l92 engine for cable operation…..or is that going to give the new PCM the fits without the gas petal?
Any input welcome.
Old Oct 18, 2007 | 10:13 AM
dmoss69's Avatar
nevermind....it isn't worth it.
Old Oct 18, 2007 | 02:56 PM
silver-mod-o's Avatar
Custm2500's #1 Fan
stroke your stocker and be done with it...
