LSX and What to do?
With this comes many questions and queries. I know a bit, but I also have alot of questions and would rather be prooved wrong than continue being niave.
So, the questions begin.
Boring an engine out has alot of positive ends to it, and the LSX can be bore out to 4.250".
What are the implications of boring an engine out?
Is there a happy medium or is bigger ALWAYS better?
What are the positive ends to it exactly?
With the engine bore out I would have to buy enlarged pistons.
What should I be looking for in pistons?
Next comes heads, springs, and rockers.
Will bore affect any of this?
What should I look for as far as the heads and such fitting? I read somewhere that the larger pistons in a bored out lsx could damage the heads if not calabrated correctly? Whats this about?
I will appreciate everything you can do to help me out. There will be many more questions and postings by me as I progress in building the block up.
Thanks guys.
I will NEVER have anyone else build my motors. LME is the best hands down. They have built 2 for me this year..
Next, are you sure you want to do the conversion? It sounds like you're not real savvy with projects of this sort in the first place. There's way more involved in building a fast car than the engine. Especially if using an LSX block. You're going to have to put a new harness and computer in your car and will likely have to do a little more than that to make this work. Plus, you have to consider how much it's going to cost you to get a tranny and rear end to hold the power you're seeking. It's very easy to run that cost up in a hurry. I'm in the middle of my build and have more than 10k wrapped up in my engine alone (which isn't even done yet). I still have to get all the other parts to support that. I'll likely have 20k+ spent in the total drivetrain, fuel system & cooling system when all is said and done.
Reliable, fast, cheap... you may pick two.
