price of trickflow ls2 heads bare?
Old Jan 3, 2008 | 07:36 AM
BigDB's Avatar
Default price of trickflow ls2 heads bare?
just as the title says, I cant find the price of the trickflow heads bare. Iv found them assembled and the description says available bare but there is no price. So anyone know?
Old Jan 3, 2008 | 08:10 AM
Mike@TEA's Avatar
The part number is TFS-3061b001-c02. Suggested retail is $928.00 each. It is best to buy the assembled head because the valve's that are installed in the heads are custom ground to improve airflow over an off the shelf ferrea piece. If you put just any old valve in the head it will not perform as advertised.
Old Jan 3, 2008 | 09:26 AM
BigDB's Avatar
yes i know, iv already ordered the assembled heads, but my cam is gonna be over .600 lift so I need another set of springs. Do you happen to know if there is a shelf spring that will fit the LS2 head to handle maybe .630 lift? Im not sure if the valves are stock length or not. I know when I order my cam I can get a matched set of springs but i need to know the valve stem length.
