MAF wont fit inside my volant
Old Jan 26, 2008 | 12:36 PM
snatch's Avatar
Default MAF wont fit inside my volant
Hey guys,
I have what I think is a stock MAF and it will not fit inside the volant intake tube. Are there any tricks?
Thanks,
Shane
Old Jan 26, 2008 | 12:45 PM
rickyracer25's Avatar
boil some water, stick the intake tube end in the hot water, that should soften the end up and help get the maf in there.
Old Jan 28, 2008 | 06:46 PM
Doc99SS's Avatar
With the finest saw blade that you can find, cut two 1/4" deep slots 180 degrees apart. This should allow the tube to open enough for the MAF to slide in. You will then tighten the metal strap, keeping the joint closed. It has worked for me in another situation.
