LS2/GTO steering pump output size
EDIT: See post 3.
It's a factory GTO/LS2 power steering pump.
Thanks.
Are you looking for the hose sizes from the reservoir to the pump (rubber hose)?
From the steel return line to the reservoir (rubber hose)?
or the outlet from the pump to the steering gear?
I just took the stock fitting off the pump. It's held in place with one bolt and an o-ring keeps the seal, so I can't just add the AN fitting. The stock piece points up, anybody know if I can buy one that points down or straight out?
