2000 ta ls3 build?
Old Feb 21, 2008 | 04:46 PM
kail's Avatar
Default 2000 ta ls3 build?
Im debating the logic of pickin up one of the hot cammed ls3 engines, throwin the 24x reluctor wheel on it, and puttin that in (before someone jumps on me for that, i know its not exactly a "throw it in", its an engine swap, and im prepared for what that entails. im thinkin LS3 376hp/480tq ,
this thing is only 6500. anyone have anything to say for or against? problems id have with it, issues theyve run into with it. its going into a 2000 trans am btw.
im wondering if the motor mounts will be the same, if id need anything. anything to be aware of. help would be appreciated.
im gonna talk to sdpc and see if they cant get one because i remember them sayin somethin about moddin the engine to work in the 2000 ta
found it on gm parts direct:
GM PART # 19171224
CATEGORY: Eng Asm (shipped only to local fedex hub 4 pickup)
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $8,928.57
OUR PRICE: $6,500.00
Old Feb 21, 2008 | 06:04 PM
Robin L's Avatar
LS1Tech Sponsor
I am going to install one in my 98 Z28 Street car.
But then again I might be biased..............
Robin
Old Feb 21, 2008 | 07:21 PM
drain89's Avatar
search....I've already discussed it at length. as has the ls2 swap which is identical.
Old Feb 21, 2008 | 11:52 PM
kail's Avatar
^^ill take that one, my fault, work wont let the search work for some reason, and i got impatient so just the reluctor cam sensor, and the plug n play harness. sweet
Old Feb 22, 2008 | 11:50 AM
drain89's Avatar
here's a link to everything you need: https://ls1tech.com/forums/showthrea...&highlight=l92
