Ls2 carb and front Distributor
Old Apr 8, 2008 | 07:27 AM
Black_Tiger's Avatar
Default Ls2 carb and front Distributor
my buddy has a LS2 engine from a c6 and he want to make it a carb with the front distributor what parts # should he go with ? and I herd he mast use a ford distrib what is the best one for cam only ?
Old Apr 12, 2008 | 09:49 AM
any advice ?
Old Apr 13, 2008 | 07:40 PM
jay_lt4's Avatar
it would be a lot cheaper to just get the msd box to fire the coils and get a carb intake
if you go with the front mount dist you need the cover, ford dist, special water pump to clear the new timing cover, and a whole ignition system anyways
Old Apr 20, 2008 | 12:43 PM
what the best cam he can go with ?
Old Apr 20, 2008 | 02:11 PM
ohshixgoat's Avatar
there is no cam that he really cant go with .....
Old Apr 22, 2008 | 01:12 PM
HuggyBear67's Avatar
LS Front Distributor Drive Cover = pn 88958679 (ford style dist, and mech fuel pump NOT included, requires use of aftermarket dampener).
LS2 Carb Intake = pn 88958675
Old School Valve Covers = pn 25534398 or pn 25534399
Water Pump = pn 89018052 (stock on all LS2/3/7 engines) I think you need spacers to clear the drive cover or the 'long' water pump from Wegner Motorsports.
You can also check out Wegner Motorsports at http://s41657.sites80.storefront-hos...m/default.aspx.
