valve cover ?, pcv ? and more
Old Apr 13, 2008 | 01:51 PM
89Formulaws6's Avatar
Default valve cover ?, pcv ? and more
it seems my driver side valve cover wont go on cause it wont fit inbetween the rockers (l92 rockers) anyone have a couple of pics of what needs to be clearenced?
also instead of putting a breather on the oil cap, could i put a breather on the driver side valve cover and run one line from the pass to the pcv to a catch can and then to the motor and then cap off the other port on the pass cover ?
Old Apr 14, 2008 | 02:18 PM
noone?
Old Apr 14, 2008 | 04:27 PM
JoeyGC5's Avatar
I had to grind the inside ribs smooth to clear my Harland Sharp upgraded L92 rockers
Old Apr 15, 2008 | 08:16 AM
TLewis4095's Avatar
You should be able to clearance the inside of the valve covers to fit.
On the PCV system, yes....if in a non-emmissions state you can run a breather on the drivers side & run a hose on the pass side to a catch can & then to the PCV valve & the intake vac source. This way you are flushing the harmful vapors & gasses through the entire crancase & the catch can (if a good functioning one) will trap the oil vapors.
