tried to start the 408 today
Old Apr 19, 2008 | 04:51 PM
89Formulaws6's Avatar
Default tried to start the 408 today
today i tried starting the 408 today and it started for a sec then immediatly died then it just backfires real loud so i didnt try after the 2nd time
heres a few things im thinking
old/bad gas the gas is from november and my compression is now 11.4:1 now
didnt have the o2's plugged in but my car started last year without headers with just the ls1
the cam was degree'd
heres a video/s
i just wanted to get a couple ideas before i put the o2's and some fresh 94 in it
the o2's i have are from a corvette but the connector is different so im gonna cut and splice
i got
1 light brown heater?
1 purple pcm?
2 light brown power and ground?
its open headers here
cam specs are high 230 duration 6xx lift and a 114 lsa
http://videos.streetfire.net/video/f...art_158020.htm
http://videos.streetfire.net/video/f...t-2_158021.htm
Old Apr 19, 2008 | 05:19 PM
wyndzer's Avatar
Cam sensor, if it's backfiring while trying to start then it's probably 180 out.
Old Apr 19, 2008 | 07:34 PM
DROPTOPLS1's Avatar
I think the coil packs are wired wrong and it is firing out of order.
Old Apr 19, 2008 | 07:36 PM
HSV-GTS-300's Avatar
Backfiring and Tach not working ?
Swap the outer wires for the cam sensor.
1------->3
2------->2
3------->1
Old Apr 19, 2008 | 07:50 PM
crap well what color wires go to the map cause i had to lengthen them for the l76 intake and thought i had the right ones, i thought the cam sensor can only go in one way or it wont bolt down
the tach does work
Old Apr 20, 2008 | 12:35 AM
so i did some thinking and remembered
my block is a gen 3 style 6.0 block the cps is on the side of the block, my tuner said just try some fresh gas
Old Apr 20, 2008 | 01:52 AM
jdmoore144's Avatar
They make a wiring harness that will work with the l76. Its plug and play also.
