Ported fast 90/90 swap...*Results*
Vids of the dyno run
http://s69.photobucket.com/albums/i6...ECSPulls-1.flv
I know the numbers are just numbers, so i wasnt upset with the 417, especially considering how much the car improved at the track. Last season i was able to run an 11.73 @ 118 1.70-60', in 30* air and a negative 1000+/- DA. I basically took the car right off of the dyno and drove to the track for some real world numbers. Temperature was around 70* (not sure of the DA but it was far from perfect air), and the car was prepped the same as it was back in october. My final results from the track were 11.67 @ 119mph spinning to a 1.71 60'. Now considering the air wasnt the best i didnt expect to beat my old time. This ported fast really carries the car down the track and it really woke the car up all over (not just up top). Im extremely impressed with this piece and would reccomend Tony's services to anyone! Best part is i know i can go back this fall when the negative DA's return for an even faster pass, my guess is its worth at least another 2 tenths and 1.5-2mph, especially considering i wasnt hooking at all cause of a weak diff that needs replacing.
here are the vids of my runs that night
Thanks for the compliments!
car pulls MUCH harder over all and doesnt run out of steam up top like it did before. It'll pull clear to 6800 without any trouble, and judging from my curve i can see why. Definately a noticable improvement over the stock LS2 intake/TB combo. Good luck with your head choice, either way you go im sure you'll be happy, they are both great heads when setup properly.
Dynos are just tuning tools though, get it to the track and see what she does; the trap speed will be as good of an indicator of your rwhp.
Your car is putting down a bit more than 417. My car put down 457rwhp/429rwtq on a very optimistic mustang dyno. And on 235s at the track it was a 12.53 at 118.6mph spinning 1rst and 2cd. I need the driver mod or more practice because i,m used to doing 40 rolls. Thanks for your write up about the fast. I,m ordering one on monday with some of Tonys magic port work
