LS2 with LS6 parts - many engine codes
Old May 12, 2008 | 12:05 PM
LS6/LS2 V's Avatar
Default LS2 with LS6 parts - many engine codes
I just got an 05 Caddy CTS-V. The previous owner replaced the blown LS6 motor with an 06 LS2 from a GTO.
However, he re-used several parts from the LS6, TB, MAF, KS, PCM ...etc.
I have a dozen DTC's keeping me from passing inspection.
The car hesitates at 1300 rpms on full throttle, and breaks down again around 4000rpm's and hesitates.
I've read the threads on MAF ...etc. How to find out if larger cubes (LS2) is confusing the MAF/PCM ...etc. thnks
Old May 14, 2008 | 10:47 PM
black00TA's Avatar
i wouldnt touch that with a 20 foot stick.
Old May 15, 2008 | 01:02 PM
Disturbed Bird's Avatar
has it gotten retuned for the new motor? and there are extension harnesses you have to buy for all those parts that has thrown a code to have them hooked up correctly.
Old May 15, 2008 | 03:23 PM
BlwnLs1GTO's Avatar
Read the codes and then take the correct action to fix them. Done.
Probably missing the needed relocation and harness extentions.
Old May 19, 2008 | 10:33 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
That's not an unusual swap at all. Post the codes for us and we'll try to help you from there
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 19, 2008 | 12:27 PM
HSV-GTS-300's Avatar
I've got an 05 LS2 with LS6 intake, LS1 coil packs, SVO #30 injectors, mafless tune, 78mm cable TB, LS1 knock sensors......LS1 PCM. Made the knock and cam sensor extensions ourselves.
It fired up and ran fine straight away, but yeah you do need to alter the tune to suit the larger cubes.
Mine hasn't missed a beat in 3 years.
Old May 19, 2008 | 01:50 PM
Blindmelon's Avatar
Did you do a crank relearn? LOL
