LS2 intake...injectors slanted into the heads???
Old Jun 3, 2008 | 09:13 PM
theblur98ss's Avatar
Default LS2 intake...injectors slanted into the heads???
I'm in the process of putting an ls2 intake on my ls1 motor. I put a set of aftermarket fuel rails and instead of being level like there were on my previous intakes the rails and slanted towards the center of the motor. After looking at the injector cups on the intake it appears that's how they're setup. Has anyone else noticed this? Kinda makes the rails look crappy but just want to make sure this is right.
Old Jun 9, 2008 | 02:17 PM
pmj341's Avatar
one bank points fwd and the other points back , yes they do, I just removed one from my LS2 and installed a FAST 92mm.
Phil
good luck
