LS1 Oil pan on LS3? All pans the same?
Old Jun 14, 2008 | 03:00 PM
VintageCamaroChris's Avatar
Default LS1 Oil pan on LS3? All pans the same?
I have searched but im trying to determine if the they all have the same block to pan bolt pattern and or which pans don't interchange on LS1-2-3? If you search fitment you usually just get info on frame and ground clearance..
Thanks!!
Chris
Old Jun 14, 2008 | 10:11 PM
fast377's Avatar
The LS1 oil pan will bolt to the LS3/L92.
Old Jun 14, 2008 | 10:12 PM
fast377's Avatar
This should answer any question you have about LS1/LS3 swap stuff.
https://ls1tech.com/forums/showthrea...light=ls3+swap
