Z069 Vette Build...Fuel Regulator question..
Old Jun 22, 2008 | 01:04 PM
Zo69's Avatar
Default Z069 Vette Build...Fuel Regulator question..
What's up fellas....My name is John and I am the one building the "Z069"...69 stingray with an LS7
I'm on the Vette forum if you'd like to see the build.
We purchased an LS7 from "Turn-Key" motors...its a 630HP verison of the 505 HP Z06 engine.
It been a long build.....
Anyway, check out these pics....this is how I was told to plumb the regulator.
Others have mentioned its wrong....however the fuel-rail has only one port, so the regulator cannot go on the rail, (with one port plugged and using only the return.)
I am close to firing this thing up...just thought I would check with this site as well.
Later
John
The barbed fitting will have the vacuum line ran to the port on the back of the intake and a guage will be present as well:
Here's a chassis shot:
Old Jun 23, 2008 | 09:04 PM
JVetthead's Avatar
Cant help with your problem but I definatly would not mount that regulator right above the headers!!
I also have a C3-LS1 project on the back burner... what engine mounts did you use?
