Obtainable power goal???
L92 block
CNC'd L92 heads
custom cam around .650-.670 lift 250ish duration on a 108lsa
4.100 bore 4.100 stroke making 433 cubes
Should be just below 12-1 compression
Okay my real question is will/could this make 700 flywheel HP?
Dont say build less cubes and use a power adder...i want to build a NA combo
Thoughts and info on similar setups appreciated.
Thanks David
L92 block
CNC'd L92 heads
Thanks David
It is possible, but I would hire a professional to spec the cam. You may not need as much as you think.
Or you could buy the same setup almost from Dragaholic on here and save a ton of money....
