how to check ls2 coil?
Old Jul 28, 2008 | 11:08 AM
CGrant's Avatar
Default how to check ls2 coil?
HI, whats the correct way to check a ls2 coil?
I checked for spark and it has spark but what reading should i be checking for, i didnt see anything while trying a search?
Basically i need to know how to check a ls2 coil?
Thanks!
CG
Old Jul 28, 2008 | 11:14 AM
fossil's Avatar
I swap with a good coil from another cylinder and see if the missfire goes to that cylinder
Old Jul 28, 2008 | 11:49 AM
WMSuperSport's Avatar
After battling a bad coil myself, I found no way to accurately test the coils with regular tools(multimeter). After some research, I ended up doing the ol' swap and see how it runs test. It was pretty obvious when I revved it up, once I replaced the correct coil.
