help please! will l92 heads work with lq4 block
Old Aug 13, 2008 | 05:04 PM
bryon 933's Avatar
Default help please! will l92 heads work with lq4 block
I've been reading about the l92 heads and was wandering if they will work with lq4 block? I know it will require the right intake but if it will thats the way I am going. Thanks
Old Aug 13, 2008 | 05:31 PM
merriman44's Avatar
Ya it will work just fine. Just make sure you pair it with a L76 intake and you should be ok.
Old Aug 13, 2008 | 05:40 PM
bryon 933's Avatar
sweet! now just have to figure out the compression and cam combo, and go from there. thanks
Old Aug 14, 2008 | 10:15 PM
cam75w/ls1's Avatar
You have to run a small cam. If you run anything "big" it will hit valves. Diamond pistons sells pistons for the l92 heads on a 6.0 block. If you run a LQ9 that has dished pistons then it can be a little larger. I had to research this before I pulled the pistons on my motor.
Old Aug 15, 2008 | 06:20 AM
veee8's Avatar
Other way around, the LQ4 has dished pistons, the LQ9 has flat tops.
Several aftermarket companies have L92 specific pistons. I run the Mahles.
Old Aug 22, 2008 | 12:07 PM
hookemdevils22's Avatar
Car craft ran a carb'd LQ4 with L92 heads and a comp cams XR281HR cam, (228/230 @ .050", .571/.573" lift, 112 LSA) with no problems. It made 550 hp @ 6,800 rpm.
Car Craft Article
Old Aug 22, 2008 | 12:59 PM
69LT1Bird's Avatar
I have 1400 miles on the one in my sig with no problems so far. Still haven't dynoed it yet and just got my dr's a couple of days ago, so no stirp data. Now I need new tires with more backspacing, never ending fricking circle.
