Ls7 Manifold Height??
Old Aug 18, 2008 | 09:10 PM
bergls1's Avatar
Default Ls7 Manifold Height??
No guessing here!I have very critical hood clearance. Have any of you builders concisely measured the finished/ built height of the LS7 vs. LS6 manifolds? It appears by looking that the LS7 mani may be a scoshe shorter...but are looks deceiving? THANKS IN ADVANCE, Dave
Old Aug 19, 2008 | 07:33 AM
69LT1Bird's Avatar
Looking at the LS7 manifold from the front, draw a vertical line through the throttle body opening, from the top to the bottom of the manifold is 139mm or 5.47 inches high. if you have a LS1 or LS6 intake available you could compare this measurement.
Old Aug 19, 2008 | 06:48 PM
bergls1's Avatar
Thanks, I will post results in the AM.
Old Aug 21, 2008 | 12:35 PM
bergls1's Avatar
This may not be as easy as I thought...I am coming up with appx. 150mm net height with the LS6 manifold. I measured from the machined surface on the top of the block (right next to throttle body / drivers side) laying a staightedge accross the top of the runners. I then subtracted 10mm to account for the cast vally cover and gasket. It would be great to hear from someone with both LS6 & LS7 manifolds already off the motors. Thans, Berg
