L92/LS3 head casting numbers
Old Sep 10, 2008 | 02:40 PM
pwrtrip75's Avatar
Default L92/LS3 head casting numbers
How many different castings are there of these heads and what is the difference?
Thanks.
Old Sep 10, 2008 | 06:07 PM
HSV-GTS-300's Avatar
Search: Key Word(s): 5364
Old Sep 10, 2008 | 06:51 PM
WKMCD's Avatar
Short answer is there is no difference if you are looking for CNC'd heads. One is a rougher surface than the other.
Old Sep 12, 2008 | 09:02 AM
8ByGoat's Avatar
823's are superior if you are not porting-but I think you will be hard pressed to find some.
They are a "smoother" casting and have bigger exhaust ports.
Old Sep 12, 2008 | 01:24 PM
69LT1Bird's Avatar
The exhaust port is not that big of a difference, a port match to the exhaust gasket would take that difference out of the equation. Also, the smoothness difference of the ports is from the casting process used to manufacture the heads. The truck ones are made in a larger quanity so cost and speed determines that process. A bit of light sanding and polishing and they will look like twins.
Plus if you buy new ones today, the L92 and the LS3 share the same service part number - 12615361
