Guess the dyno result.. win a prize..
Old Oct 17, 2008 | 10:15 AM
WYATT318MOPAR's Avatar
547 hp 516 ft lbs...Seems reasonable. what is the compression on the engine??
Old Oct 17, 2008 | 10:27 AM
Stang's Bane's Avatar
Originally Posted by wzup1000
I had a friend with a very similar setup make 575 at the wheels... so at the flywheel, wouldnt around 700 be about right???
If he made 575 at the wheels out of a 402 with afr 205s, a sub 240 cam and a fast 90, then he was on a happy dyno. That is about a 600 FWHP set up.
But yeah, 575 rwhp should be ~ 675 fwhp though.
Old Oct 17, 2008 | 10:31 AM
ssman00's Avatar
657hp 642tq
Old Oct 17, 2008 | 12:00 PM
wzup1000's Avatar
damn, maybe so on the happy dyno part...lol...
Old Oct 17, 2008 | 12:31 PM
bigwindsor's Avatar
577hp / 527tq
Old Oct 17, 2008 | 07:34 PM
Steve1969LS1's Avatar
And the winner is???
Hell, I don't know.. who was closest. lol
We had some electronics issues but the best pull was 561/534
Less than I was hoping but no too shabby and the torque curve was pretty nice. I will post the graph in a bit.
I also want to re-calculate my compression..
-3cc piston
66cc chamber volume heads
Stock GM gasket
4.005 bore
Where is that calculator?
Old Oct 17, 2008 | 09:04 PM
CalSpeedPerformance's Avatar
Guessing at the piston .007 out of the hole, that puts the compression at 11.05:1
Old Oct 17, 2008 | 09:11 PM
Haans249's Avatar
posts 9 and 13 are tied with the same deviations, at a total of 25, so they are tied!
Old Oct 17, 2008 | 10:01 PM
DrkPhx's Avatar
I like this one: http://www.rbracing-rsr.com/compstaticcalc.html
Old Oct 17, 2008 | 10:43 PM
cdubbzz's Avatar
woohoo, I'll take a hot brunette w/ big *****
Old Oct 17, 2008 | 11:30 PM
LS1-Master's Avatar
565 hp - 546 lp
Old Oct 17, 2008 | 11:44 PM
  #32
Originally Posted by LS1-Master
565 hp - 546 lp
Wow.. you might have won if you had posted BEFORE I gave the results..
Old Oct 17, 2008 | 11:45 PM
  #33
PM me your name and address...
Old Oct 18, 2008 | 01:34 AM
  #34
litemup02's Avatar
uuhhh 561/534 is my guess then
Old Oct 18, 2008 | 07:43 AM
  #35
LSWONGTO's Avatar
Nice results for a mild cam. Why did you go with the 205 heads?
Old Oct 18, 2008 | 05:22 PM
  #36
Because they are the heads I had.. Mamo thought they would flow fine for this combo especially since they had been worked over a bit.
Best pull was 561/534
Was hoping for more but it's better than before. Notice that the curve is up everywhere except the very top. More toque is a good thing especially for what I'm doing.
Old Oct 18, 2008 | 05:55 PM
  #37
1FASTBIRD's Avatar
That is some good number there bro
Old Oct 19, 2008 | 12:41 PM
  #38
litemup02's Avatar
I like that Katech set up.. wish it were cheaper
Old Oct 19, 2008 | 02:03 PM
  #39
3timeracin's Avatar
Actually it is pretty easy to figure out a 402ci engine moves 270cfm per cylinder at 6000rpm thats 540hp @ 6000 given your heads flow 270cfm wich they do then add 3% for every point of compression over 10.1 and your 556hp within 1%. If anyone is interested ? Stan Weiss offers some great calculation pages that will get you close if you have a build going use this link http://users.erols.com/srweiss/tablehdp.htm
Old Oct 19, 2008 | 06:19 PM
  #40
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That is a really good link. I'm going to add that to my list.
