CNC L92 valve ?
The set that I have has the L92 Valves. I think that when they made the run of heads they used complete L92 as their basis. At the time of the run the LS3 were not available.
I am going to order a set of the LS3 Valves and swap them out after a little dyno use.
Robin
The installed height on the LS7 is taller. I would use a valve spring from Lunati.
FORD RACER
Robin
