rod bolts in an L92/LS3
Old Oct 18, 2008 | 08:44 AM
Ramairbird's Avatar
Default rod bolts in an L92/LS3
For an engine that will see 6500 rpm max. do you guys recommend upgraded rod bolts on these engines? I wasn't sure if this was like LS1's where it is a good investment to upgrade. Thanks.
Old Oct 18, 2008 | 09:20 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Katech rod bolts
Old Oct 21, 2008 | 01:13 PM
LSX Wizard's Avatar
The GMPP LS3 crate engines (LS3, LS376/480, LS376/515 & CT525) use stock rod bolts and they have a recommended max RPM of 6600-6700. Chances are you'll be fine at 6500.
Old Oct 21, 2008 | 01:15 PM
ineedashortblock's Avatar
It never hurts to be too strong, but it always hurts to be too weak.
Old Oct 21, 2008 | 02:01 PM
1.8t's Avatar
There are numerous shops reving the LS3's out to 7k over on corvetteforum. I, so far, have had no issues reving to 65~6600rpm. I honestly don't think you would have even the slightest problem. I have yet to hear of a failure on these motors related to the rod bolts. However, if you want cheap insurance, go for it.
