LS7 question
Old Oct 24, 2008 | 03:40 PM
Najania's Avatar
Default LS7 question
Is it possible to switch to a wet sump system on a LS7 engine to make a swap easier?
And is there any OD tranny that can withstand the vigors and power from an LS7 engine? A standard 4L65E cant for sure i know
Old Oct 24, 2008 | 03:49 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You can build the short-block with a standard short snout crank for wet sump if you want to. OR, I have seen a spacer that you can put onto the LS7 long snout crank that enables you to run a standard balancer off an F-body or Corvette. That's not my preferred method, but has been shown to be just as reliable in average street/strip use.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 24, 2008 | 04:14 PM
pillboxesghost's Avatar
Default Wet Sump LS7
There's lots of info on this conversion if you do a search!
Here's a "Cliff's Notes" version.
Change to wet sump oil pan (several will work), change windage tray and oil pick up to match new pan. You'll need dip stick with matching tube (you get to drill block for tube).
Change crank timing gear to Ls2, change oil pump to standard type, change front timing cover to ls2 type (has crank sensor).
Shorten crankshaft (about 1" AIR) or have sleeve machined to push crank pulley back against crank timing gear. I'm told the crank can be shortened with a hacksaw??? However, if you've got the $$$ to buy an Ls7 why "shade tree" the crank snout?
You may (or may not) be able to reuse the Ls7 crank pully. If not, buy a pulley that matches your accessories (Camaro, Vette or truck).
4l80E (or 6l80E/6L90E) tranny should work fine with Ls7.
I suspect it's just as cheap (cheaper?) to purchase an aftermarket 8 qt. dry sump oil tank, tank breather and the required hoses. All depends on what you can get used. That is, assuming the dry sump pan clears and you have space to mount /route the dry sump accessories.
I'm sure if I've omitted anything someone will chime in!
Old Oct 24, 2008 | 05:14 PM
Najania's Avatar
Thanks.. Great info. It will be more "cool" to run a dry sump setup, and probably cheaper and certainly better so i'll try and forget i've ever asked
It is going into a c3 corvette. A 71 or 74 vert. Not sure.
Thanks for info
Old Oct 24, 2008 | 06:09 PM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
We have them in stock. #SDLS7SPCR $29.95
Brian
