LS2 Build
Old Nov 12, 2008 | 05:13 PM
SlwSVT's Avatar
Default LS2 Build
Hello,
New to the forum and am in the process of completing my build on my 05 C6. Can you all tell me what you think of my build, what to expect power wise and so forth?
243 Heads Ported and polished milled .030 (314cfm flow on the intake and 245cfm flow on the exhaust side) .045 Trick Flow Head Gaskets. Shooting for 11.7-1 compression
Comp Cam 228-232, .588 .595, 114 Installed straight up
Patriot Springs, 7.35 push rods, 1.7 Full Roller Rockers
Comp Cam Double Rolling Timing Chain
25% Underdriven Crank Pulley
Fully Ported FAST92
Kooks 1 3/4 Long Tubes, Off Road x pipe
HP Tuned
Car also has a wet kit on it with 150 jets. I will eventually be adding a 4.10 RPM differential.
Thanks
