Leakdown Results
Old Dec 2, 2008 | 12:07 AM
Piersin's Avatar
Default Leakdown Results
So I had a compression and leakdown test on a new 440 LS7.
They're all 12-14% except one with 19%.
The rings are plasma moly Hellfire rings for nitrous possibly later.
Results are after 500 miles.
Does this sound ok to you?
Old Dec 2, 2008 | 01:13 AM
1994Z28Lt1's Avatar
Engine hot or cold? Forged pistons i assume? ring gaps? these would be helpful, doesn't sound bad though still probably has a little breaking in to do
Old Dec 2, 2008 | 07:47 AM
DBN's Avatar
DBN
No. I recently did a leak-down test on my 427 and all cylinders (except one) were under 5% leakage on a cold engine. This engine has over 100 passes on it. To me, anything over 10% is not good.
Old Dec 2, 2008 | 01:51 PM
GM WORLD CLASS's Avatar
id say 25% leak down is acceptable on a cold engine. definitaly no more than that.
