LQ9 Machine work Questions
Old Dec 8, 2008 | 05:32 PM
thisjustaintrite's Avatar
Default LQ9 Machine work Questions
Im working on building a lq9 block the deck surface needs to be cut .015 and im not very familiar with these block how much is safe can cut off the deck and what would the 0 deck be for this block
Old Dec 11, 2008 | 07:26 PM
rhubar's Avatar
.015 isn't all that much for a 6.0 block. Out of all the blocks i've machined i've taken anywhere from .010" to .020"
Old Dec 11, 2008 | 08:25 PM
KCS's Avatar
KCS
Moderator
How did you determine that .015" needs to be taken off?
0 deck is gonna depend what stroke, rod length, and piston compression height you end up using.
