LS3 sleeve length ?
Old Dec 26, 2008 | 06:17 PM
red 454's Avatar
Default LS3 sleeve length ?
are the stock sleeves in an ls3 the same length as ls1, ls2,
what are ls3 blocks like strength wise for darton dry sleeving are they aney better or worse then ls1 ls2 ??? can you stroke a stock ls3 block to 427 ??
Old Dec 26, 2008 | 11:52 PM
racer7088's Avatar
Yes same length as others and yes good for sleeving if you want and yes you can do a 427 wit the right piston as I do all the time.
Old Dec 27, 2008 | 12:40 AM
red 454's Avatar
Originally Posted by racer7088
yes same length as others and yes good for sleeving if you want and yes you can do a 427 wit the right piston as i do all the time.
thanks erik
